Configure Directed Broadcast
A directed broadcast is a frame sent to the subnet broadcast address on a remote IP subnet. When you disable (or suppress) directed broadcasts on an interface, all frames sent to the subnet broadcast address for a local router interface are dropped. Disabling directed broadcasts protects hosts from possible denial-of-service (DOS) attacks. By default, this feature is disabled on the device.
Enable directed broadcast on VLAN 2:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface vlan 2 Switch:1(config-if)#ip directed-broadcast enable
Display VLAN IDs with directed broadcast enabled:
Switch:1>show ip directed-broadcast vlan
                               Vlan Directed-Broadcast
    VLAN ID  DIRECTED-BROADCAST
    2        true
The following table defines parameters for the ip directed-broadcast command.
                                                   Variable  |
                                                   Value  |
                                                   enable  |
                                                   Enables the device to forward directed broadcast frames to the specified VLAN. The default setting for this feature is disabled.  |
